PLASTIC SHEETS - COMPOSITES - NESTED BASED - HIGH VOLUME
Complete three axis CNC routing systems with single or dual in-line tables for nested base, composite or plastic sheet material.
Available Table Sizes: 5'x10' (1.52m x 3m), 5'x12' ( 1.52m x 3.6m), 7'x12' (2.1m x 3.6m), 7'x20' (2.1m x 6m)
A direct driven spindle with a speed range up to 24,000 RPM. The high-frequency spindle is cooled with an electric fan for quieter running and contains ceramic bearings for longer life and for less maintenance. The 12 HP (9kw) spindle provides the user with a heavy duty, precision spindle which provides high performance and reliability. Standard
Mounts between the two tables and holds the tapered tool holders. When the program calls for a tool change, the head moves to the holder and places the tool into an empty space, it then moves over and picks up the appropriate tool, and then continues the program. Standard (on MTR 30 DT)
Mounts behind the rear of the table and holds the tapered tool holders. When the program calls for a tool change, the head moves back and places the tool into an empty space, it then moves over and picks up the appropriate tool, and then continues the program. Standard (on MTR 21 Single Table)
The Thermwood SuperControl is a feature rich, high performance CNC control system. Thermwood, the only major CNC router manufacturer that designs and builds its own CNC control, is a leader in implementing advanced control technology. As a result, Thermwood has been granted more patents on CNC router technology than all other CNC router manufactures in the world, combined. Standard
A user-friendly nesting package integrated into the Thermwood control to nest various parts into sheet stock, thus creating a better yield. Also accepts layered DXF files. Standard
We are by your side during your 5 Day training course at our modern, state of the art center (devoted specifically to educating our customers). This is, by far, the fastest and most efficient way to learn. Our machine operator/programmer courses are located adjacent to the machine training lab, where students complete the prescribed projects on a specific training machine utilized only for training purposes. Then, when it comes time for practical applications on a full sized machine, Thermwood's training lab is equipped with a CabinetShop 45 outfitted with all major options and features. Real production-type parts are cut. What a confidence builder! Standard
The 18HP (13 kw) spindle (3,000 to 20,000 programmable RPM). Accepts HSK F63 toolholders as well as Thermwood Aggregates and is equipped with an electric fan.Optional
Provides an automatic method of measuring tool length and entering tool length offset numbers into the control. This automatically compensates for the new tool length, eliminating the need to precisely locate the cutter bit. It provides a highly accurate method of adjusting tool length for pocketing or profile edges. Optional
Provides positive pressure, air/oil lubrication to the linear trackway bearings and the ball screws This has two major benefits: First, it eliminates the lubrication points which must be servided each shift. Second, it provides positive pressure to the bearing, preventing contamination from entering the bearing. This allows the machine to function in difficult, dusty or hostile environments. Optional
This option consists of tool holder arms and five tool holders, which mount in an arc around the front of the spindle and hold the tapered tool holders. When a program calls for a tool change, the tool is automatically changed at the head. Available for the primary head as well as an optional secondary head. Optional
A second head can be added to allow simultaneous machining of two parts. The second spindle includes a complete tool slide, second servo-controlled Z-Axis assembly and 24"(600mm)space bar. (Note: Bar Style tool changer cannot be used with this option). At the head Tool Automatic Tool Changer is also available for both heads. Optional
Allows the operator to route or drill horizontally and saw. While not in use, the aggregate tool body is stored in a tool holder located off the back of the table. Aggregate tooling adds a high level of machining flexibility. Optional
The drill unit is a vertical boring head with nine vertical spindles, arranged in a right angle pattern with four arranged front to back and four arranged left to right (with one additional, which is common to both). The spindles are on 32mm centers.. Optional
The rotational playback axis is attached to the top of the machine table. it is capable of accepting stock that is 8 inches (200mm) in diameter and up to 56" (1.4m) in length. The unit is designed primarily for reproducing furniture components. Optional
Guides mounted to the table perimeter for locating sheets of material. They are flipped to the up position to locate the material and then retracted to clear the area during the machining cycle. Optional
Universal Vacuum System is a unique method for holding panels to the table top for machining. A sheet of particleboard or low density MDF is used as a work surface on the top fo the table. The high flow pump vacuums through the work surface, holding the part to the table. Pumps are available as 15HP (11kw). Conventional vacuum also available. Optional
