Thanks Brian
converting .skp file to stl/hsf
brian bowden
Could any one tell me if it is possible to convert google sketch 6 (.skp) files to stl/hsf file. Google sketch has a large range of 3d file. If this is not posiable has any one a 3d file of a out door grill.
Thanks Brian
Thanks Brian
- Kerry Fullington
Re: converting .skp file to stl/hsf
Brian,
I think the full version of Sketchup will save or export files in another format that can be converted to use in eCabinets.
George Davidson probably has a good grill model
- Kerry Fullington
Brian,
George was getting an error uploading files to the forum so I put them HERE
There are stls for two grills in this zip file. You can open them in the display part editor and save them as hsf files to use in eCabinets.
