Making angle cuts
Greg Haw
Making angle cuts
Post by Greg Haw »
I am trying to make a cabinet that has one side angled at 15 degrees. I am using one cabine with 3 sides cutting the ends of the top and deck at 15 degrees in part editor,or at least trying. Is thgere away to make a pricise 15 degree cut? Closest I have come is 14 degrees. Also need to bevel the 4th side, coming from a seperate cabinet, at 15 degrees. Also haveing hard time making a tool with presice 15 degree angle to make those bevels. Is there away to do this? Greg
Re: Making angle cuts
Can you sketch something on paper and post a picture. It will be easier to interpret.
Simon Randall
Company Name: westone-group.com
Country: UNITED KINGDOM
Post by Simon Randall »
post what you have (even if the degrees are not right).
so if I have it right you need a cabinet a wide at the back and b wide at the from and you only now that the side are set to 15 degrees?
and as to the 4th side??
Simon
Greg Haw
Post by Greg Haw »
Ok I attached thew cabinet in a jpeg so you can see I hope what I am doing. What I am asking is,How do make the Profile cut and the Part Editor cuts exactly 15 degrees or make any certain angle for that matter. 45 degrees you can make a square then bisect the corners. But say you want. 43 degrees, or 25 degrees in Part Editor Is there a way to do this?
cabinet with almost 15 degree angles.
Simon Randall
I sort of see what this is but to help out the best can you post a file to we can add to are ecabinet's to fully see what it is?
Simon
Hi Greg
In the contour section of the part editor, right click angle snap a couple of times to select and deselect. There you can put in the angle you would like.
I hope this makes sense.
:D
Greg Haw
Post by Greg Haw »
Thanks Mark exactly what I was looking for.
