Can anyone tell me how the Corner Stretchers work. When you go in to Add Stretcher Settings there is an option to have
"Back" Stretchers Outside
I have no idea how to add a stretcher to a corner cabinet but this looks like it might lead somewhere.
Thanks!
Corner Stretchers
Corner Stretchers
Rick Deskins
- Company Name: Thermwood
Re: Corner Stretchers
Two type of corner stretchers: nailers and sleepers. For nailers, just select a back and then add stretcher. You can add the nailer on the inside of the back or the outside. for a sleeper, choose toe kick and a back then add stretcher.
Rick Deskins
- Kerry Fullington
Rick,
The "Sleeper" doesn't work with an angle front cabinet though. Is this correct?
- Scott G Vaal
Kerry,Kerry Fullington wrote:Rick,
That is correct. This is because an angle front cab will not always have the back and the toe kick parallel to each other.
Very nice feature.
One problem. I add the stretcher and then try to align it with the top of the cabinet. I type in the number 0 for Inset 1 and it keeps changed to -0.1875. No matter what I try, it won't let me set Inset 1 to 0.
Any ideas?
Any ideas?
Don, can you post the cabinet.
- Scott G Vaal
Don posted the cabinet to the beta site and I have tracked the issue down. Seems that the corner cabinet "back" style stretchers will position off by half of the full dado depth (and have ever since their introduction). I have this listed and should be resolved for the next release. You can get around this for now by typing in half of the dado depth for inset #1 and press enter. Doing this will get it to positioned at zero.
