drawer box front for pull-outs
Chris B Campbell
Post by Chris B Campbell »
Anyone having a problem in CN with the fronts of pull-out type drawers? (Pantry) We put a 3 point arch in the top of the front panel for a finger pull kind-a-look never had a problem, now CN shows a full circle... of course it goes off the table so were getting an X axis out of bounds?
Anyone else get this
Thanks chris
JohnLashuay
Re: drawer box front for pull-outs
Post by JohnLashuay »
Hi Chris, I haven't seen anything like this.
Can you post the cabinet?
-John
http://www.rylexonline.com
Thermwood CS 43
Chris B Campbell
Here is what I get after Nesting.
Chris
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
Can you post the cabinet file this twd was made with?
Rick Deskins
Chris B Campbell
Well I wish I could. I tried to upload the CNC File and the TWD file but these Extensions are not allowed??
Chris
Company Name: Halls Edge Inc
Post by Josh Rayburn »
Chris,
You can change the extentions to .txt and post them or zip them then post.
Rick Deskins
Chris,
We really need the ecabinets file. The twd/cnc files will show the problem, but it will not helps us tell you why you have the problem or how you might be able to fix it. Please post the ecabinet file.
Rick
Rick Deskins
Chris B Campbell
I thought ecabinets file was a TWD created by ecabinets? So I am not sure what or how I get you what you need.
Chris
Rick Deskins
I need either the ecabinets job file (ESJ), cabinet file (HSF), or asssembly file (ESA) that was used to create the twd file.
Rick Deskins
Chris B Campbell
Hope this works
Draws.esa
(1.68 MiB) Downloaded 1498 times
Rick Deskins
Well, I tested your file going out to control nesting and all worked for me. So, there must be a setting on your control nesting that would produce this. I will need to get the export from your control nesting. Go to control nesting and load the twd you are having problem with. the go to file->Export and save off the export file. It will be a *.cab file. Then post that and hopefully we can find the root of your problem.
Rick Deskins
Chris B Campbell
???? << Go to control nesting and load the twd you are having problem with. the go to file->Export>>>???
Okay, Load file, bottom of screen F5 (File) there is no export button? I can save a file (F2) but it is the CNC file.
Chris B Campbell
$&*(^*)_(@#.... MONDAY MORNING!!!
Here Ya Go.
Chris B Campbell
Well it wont allow the .cab extension
Rick Deskins
Can you email the cab file to cabinets@thermwood.com?
Rick Deskins
