how to dado all the primeter edges of a board
May Cui
Company Name: misani
Post by May Cui »
I have attached 3D model how I want the board to be machined. I am a new user of e-cabinet, please explain in very detailed instruction. Many thanks!
May
dado primeter edges.png (9.26 KiB) Viewed 24315 times
Daniel Odom
Re: how to dado all the primeter edges of a board
Post by Daniel Odom »
Create a cabinet with only a back, take that part into the part editor and then use a profile modeling tool to create the rabbet. The machine would have to be set up accordingly.
Company Name: Halls Edge Inc
Post by Josh Rayburn »
Why don't you try and use a cabinet back -
In construction settings, change all the joinery to full dado with 0" fit and depth clearance.
Then adjust the back flush / side flush settings etc. until the back has the rabbets in it the way you have shown.
Hope this helps,
May Cui
Post by May Cui »
Hi Josh, that is a great help. I got it. I can sleep well now. May
May Cui
Post by May Cui »
I get your idea. will try tomorrow. Thanks!
May Cui
Post by May Cui »
Hi Josh, I followed your instruction, and did it. Now, I want to make it a frame with constraint. First, after I extrude cut the rectangular out, I saw the picture like I attached. But, after I add constraint on the the frame width 2.75", the dado around the perimeter is gone. Why? I cannot figure it out. :wall: May
dado primeter edges frame.png (11.67 KiB) Viewed 24234 times
Maybe this will help -
http://screencast.com/t/nppSAwrQP
May Cui
Post by May Cui »
Hi Josh,
That is so cool!
Many thanks!
May
May Cui
how to adjust the length of a blind dado
Post by May Cui »
Hi Josh,
I found the blind dado is way too long than the tenon, I understand it has to be longer because of the radius of the tool. I attached the pictures to show how much longer they are. How to shorten the length of the blind dado?
May
blind dado 5mm too long2
blind dado 5mm too long1
May,
You will not be able to shorten the dado operation. We have no control over this.
Sorry I'm sure that's not too helpful -
May Cui
Post by May Cui »
Josh Rayburn wrote:May,
Thank you Josh, you save me a lot of time to trouble with the length. :D
have a wonderful day!
May
