I have attached 3D model how I want the board to be machined. I am a new user of e-cabinet, please explain in very detailed instruction. Many thanks!
May
dado primeter edges.png (9.26 KiB) Viewed 25034 times
Create a cabinet with only a back, take that part into the part editor and then use a profile modeling tool to create the rabbet. The machine would have to be set up accordingly.
Why don't you try and use a cabinet back -
In construction settings, change all the joinery to full dado with 0" fit and depth clearance.
Then adjust the back flush / side flush settings etc. until the back has the rabbets in it the way you have shown.
Hope this helps,
Hi Josh, I followed your instruction, and did it. Now, I want to make it a frame with constraint. First, after I extrude cut the rectangular out, I saw the picture like I attached. But, after I add constraint on the the frame width 2.75", the dado around the perimeter is gone. Why? I cannot figure it out. May
dado primeter edges frame.png (11.67 KiB) Viewed 24953 times
Hi Josh,
I found the blind dado is way too long than the tenon, I understand it has to be longer because of the radius of the tool. I attached the pictures to show how much longer they are. How to shorten the length of the blind dado?
May
