Countertop
Calvin Williams
- Company Name: Williams Woodshop
Countertop
I have a countertop that is installing a couple inches above the top of my cabinet for some reason. Anyone know why it is doing that but none of the other tops in the room are? Thanks!!!
tim lucas
Re: Countertop
Check to make sure your cabinet is not setting a couple inches below the floor.
If your cabinet is associated to a wall, go to the wall view and select that cabinet.
Look at position on wall, make sure bottom is not a negative number.
Tim
Tim
www.TLCW.us
www.TLCW.us
Calvin Williams
Re: Countertop
I doubled checked and it's positioned at zero..... It's weird because the two other tops are fine when I constructed them. Thanks though.
Calvin Williams
Calvin Williams
Re: Countertop
One other problem I am having is that when I go to the construct countertop page one of my base cabinets appear not to be against the wall. But, as you can see when I go back to the plan view and move the wall unit out of the way it is actually against the wall. I've never had this problem before and I'm sure it is something simple. Thanks.
tim lucas
Re: Countertop
If you select the top you should be able to move it down.
The only way I can think it installed this way is if you have 2 base cabinets next to each other and they are not the same height, when you create the top it will ask you what height to install at.
www.TLCW.us
www.TLCW.us
Calvin Williams
Re: Countertop
It will let me move it side to side but not up or down
tim lucas
Re: Countertop
Go back to top editor and delete that top, then create a new top, see what happens
www.TLCW.us
www.TLCW.us
Terry Hall
Re: Countertop
Try associating the ctop to the wall. Then pull up the wall view and set the ctop to the height of top of your cabinet. This happens to me once in a while as well.
Calvin Williams
Re: Countertop
Ok, cool.... I associated the top with the wall and was able to move it down. Thanks a lot
