changing rendering color 1 side
I have a customer that wants to see color changes frequently. Is there a way to change the color on just 1 side of a display cube?
tim lucas
Re: changing rendering color 1 side
Mike, if it is just the cube, I don't think you can change 1 side
but if it is the cabinets or walls - right click on the room and select modify textures
Tim
Tim
www.TLCW.us
www.TLCW.us
Yes Tim, it's just the display cube. Too bad there wasn't a "copy & paste" for colors, wood-grains, etc.
tim lucas
Mike
I added a 12" square display cube to a room and gave it a cherry wood texture - to change the color in the room while in render mood just right click the mouse and select Modify Texture then select whatever color you need then render again Hope this helps a little
Tim
Tim
www.TLCW.us
www.TLCW.us
Thanks Tim, I have a commercial laminate column they want different colors on each side.
tim lucas
I would make it out of a cabinet using 4 different sheet goods and then you can still use the texture modify and change each side to what you wantMike Lew wrote:Thanks Tim, I have a commercial laminate column they want different colors on each side.
www.TLCW.us
www.TLCW.us
