Scott Marshburn
Posts: 867 Joined: Sat, Mar 05 2011, 7:29AM
Post
by Scott Marshburn » Wed, May 17 2017, 3:35PM
I tried to use this option but the geometry is still imported as line segments. has anyone used this feature?
Clint Buechlein
Posts: 786 Joined: Fri, May 15 2015, 1:21PM
Company Name: Thermwood Corp
Post
by Clint Buechlein » Thu, May 18 2017, 7:19AM
Scott Marshburn wrote: I tried to use this option but the geometry is still imported as line segments. has anyone used this feature?
Scott,
If your geometry coming in is line segments, it won't convert them to arcs. There was an issue found that sometimes when bringing in a DXF, the reader for DXFs would break some arcs into line segments. If we did a full update on the reader, polylines wouldn't work as they were previously. So to keep everyone happy, a toggle was added in.
David Giesbrecht
Posts: 89 Joined: Thu, Mar 03 2011, 10:40PM
Post
by David Giesbrecht » Thu, May 18 2017, 2:15PM
Just wondering were to find the toggle, could someone post a screen shot? Is it just when poly lines are detected?
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
David Giesbrecht
Post
by David Giesbrecht » Thu, May 18 2017, 2:23PM
So this is the poly line I am trying to bring in, and it breaks it into short lines.
David Giesbrecht
Z270x-Gaming 5 MOBO
Brad McIntosh
Posts: 539 Joined: Wed, May 18 2005, 6:59PM
Company Name: CNC Automation
Post
by Brad McIntosh » Thu, May 18 2017, 2:39PM
The polyline has to be originally created with line and arc segments. A "spline" like you have illustrated will be broken into small lines as there are no original arc entities which define it.
Clint Buechlein
Post
by Clint Buechlein » Thu, May 18 2017, 3:05PM
David Giesbrecht wrote: Just wondering were to find the toggle, could someone post a screen shot? Is it just when poly lines are detected?
It is available in two places, Contour Mode of Part Editor, and Shape Manager.
Brad McIntosh
Post
by Brad McIntosh » Thu, May 18 2017, 3:14PM
Here is an example of a polyline created with arc and line segments. Note: You need a panel of x=42, y=60.
PolyLine-Example-With Arcs.jpg (12.72 KiB) Viewed 16922 times
Polyline Test.dxf.txt
Remove the .txt extension. (22.61 KiB) Downloaded 1316 times
David Giesbrecht
Post
by David Giesbrecht » Thu, May 18 2017, 3:27PM
Thanks Brad and Clint. Also Ecabinets, great feature. The top one was a poly line the bottom was a spline.
David Giesbrecht
Z270x-Gaming 5 MOBO
