Hardware pattern Global Modification
David Giesbrecht
Post by David Giesbrecht »
Hi I had several cabinets that needed a different slide pattern, I selected them and went through the Global Mods procedure. Now when I go into the cabinet the default slide is changed but I have to select the fronts and apply hardware. Is this how it is supposed to work or am I missing some check box to apply it somewhere?
David Giesbrecht
8.00 GB DDR5 2133MHz
NVIDIA GeForce GTX 970 4GB
Z270x-Gaming 5 MOBO
1TB Samsung 960PRO SSD
Re: Hardware pattern Global Modification
Post by Forrest Chapman »
Make sure the cabinets to be changed are highlighted.
David Giesbrecht
Yes the pattern default changes but the actual hole pattern doesn't apply.
David Giesbrecht
Z270x-Gaming 5 MOBO
