Can't have 2 faceframe thickness materials?
Trying to make a furniture style vanity that will have 1 3/4" square legs (L&R Stiles) and the rest of the face frame material to be 13/16"
Doesn't appear that I can do that without inserting the legs as separate items not included in the FF system.
Is there a way to do it or am I stuck with adding legs as another separate pc of stock?
Dell Precision 7710
NVIDIA Quadro M3000M
512 GB PCIe NVMe - M.2 SSD
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Re: Can't have 2 faceframe thickness materials?
go into face frames and then
consturction settings then into page 2
now you can select differant material for your stiles and set the width as you want
Tim
Tim
www.TLCW.us
www.TLCW.us
Doesn't work. As soon as you switch to another thickness it populates the field with that thickness wood and you lose the side stile thicker wood.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
If you click ALL it will populate ALL to the same thickness otherwise you can set each one individuallyLeo Graywacz wrote:Doesn't work. As soon as you switch to another thickness it populates the field with that thickness wood and you lose the side stile thicker wood.
www.TLCW.us
www.TLCW.us
As soon as I click on another thickness it populates it with the first species in the list with that thickness.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
ok so you will have to work around it with 2 cabinets - one with 3 or 4 inch thick face frames and one with 3/4 frames and make an assembly
www.TLCW.us
www.TLCW.us
So the answer is no.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Here you go Leo. I did this for a customer very recently. All done in eCabs.
- Master vanity.jpg (15.16 KiB) Viewed 14813 times
- Master vanity.hsf
- (1.64 MiB) Downloaded 428 times
The legs are a display board. Anyone can do that.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Sorry. Thought I was helping.Leo Graywacz wrote:The legs are a display board. Anyone can do that.
Quite alright. Thanks for the help. I've been at this for a while now and I thought "Hey, why can't I try this" only to find out I can't make it work in the program. Figured there might be a work around someone knew besides adding in display boards.
Was trying to make it so if I resized it, I wouldn't have to move all the display boards into place. (again and again and again )
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Hi, Leo. Have you tried using stretchers for the legs?
Hi Leo
I'm not sure if this method would be a useful work around.
I don't use the face frame feature but I have found phantom parts to be very useful. (right button menu)
If you make one unit and copy it, (save as part 2), then open it back into the Cabinet editor.
Change that to your different thickness materials and varies that you cant do on one unit.
Phantom part the pieces not required on both units.
Save as an assembly.
With a bit of care all you have to do is resize both units, It should then be a resize unit 1 and resize unit 2, all the relevant changes should be applied.
As far as I am aware all the joint settings will be the same except for percentage settings (if you change the thickness).
Plus you have the benefit of being able to part edit and apply stretchers to the pieces, which is harder to do to display parts.
Thats my take on it, hope it makes sense.
Mark
Mark
That gives me something to play with. Never used phantom parts before.
Dell Precision 7710
Win 7 Pro 64-bit
http://lrgwood.com
Win 7 Pro 64-bit
http://lrgwood.com
Try this work around. Design your cabinet with the thick stiles, delete top bottom and mid rails. On page 2 of face frames change add mid rail to your thinner thickness material and add them to the cabinet to replace the rails you deleted.
- 2 thickness frame.hsf
- (880.02 KiB) Downloaded 401 times
