Inset 6 cannot be to the left of parent part...Really
- Company Name: Frank Raffaele and Sons Custom
I assume this was done on purpose in the new build. Why was this changed. That was a big advantage to set stretcher insets to zero. Now you have to give a stretcher a negative value and when you chage material thickness all those insets have to be reset. What about the weeks and months that went into building a library with all those insets set to zero. What happens to all those cabinets
Re: Inset 6 cannot be to the left of parent part...Really
Carmen,
Can you post one of the cabinets and a full description of what you are changing? There's always a possibility a bug was introduced inadvertently and we need a repeatable scenario to work with.
Clint here is a library cabinet where the #5 and #6 insets for the end panel spacers were set to zero. I would use this same practice for a left side wall filler on a euro box. The #6 inset would be associated to the left end/left and set to zero so no matter the width of the filler it would always be in the proper position. If I try to highlight the spacer now and associate again I will get the promt mentioned.
Seems like this issue was never addressed in the recent build.
