Changing preset values in 5-piece door construction
Post by Donald Thomson »
Is there a way to change the default values in the dialog where you can set 5-piece door parameters like rail and stile width, cope depth, etc? I can't find anything. Thanks :D
Scott Marshburn
Re: Changing preset values in 5-piece door construction
Post by Scott Marshburn »
Hi Donald.
You can do this in settings and preferences. Click on Default 5 Piece Door Details for Cut List. This opens a dialogue that will enable you to establish default settings for five-piece doors. The settings entered here will only be used if the door or drawer front did not get a detail setting put on it in the designer. I hope this helps.
Scott.
Thank you Scott. I was wondering why, when I changed it in preferences, it wasn't taking when adding doors to a cabinet. Now I know. :beer: :D
