Windows 7 and Me!
David Norton
Windows 7 and Me!
Postby David Norton » Sat, Oct 31 2009, 12:54PM
Yesterday I installed Windows 7 on my main P/C. I reinstalled ECabs, downloaded and installed the latest update for Ecabs.
For some reason though Ecabs will not open. It says " This version of Ecabinets has expired." I have tried uninstalling and reinstalling the update to no avail.
Can anyone shed some light as to what I am doing wrong?
Dave Norton
Re: Windows 7 and Me!
Postby DanEpps » Sat, Oct 31 2009, 1:02PM
Did you save the update to the computer before installing it? Running the updates from the download process sometimes causes problems like this.
David Norton
Postby David Norton » Sat, Oct 31 2009, 1:21PM
The update was saved to my downloads folder and run from there. I even tried copying to Ecabs root directory . I just tried redownloading the update. Nothing seems to work.
Dave Norton
Postby DanEpps » Sat, Oct 31 2009, 2:31PM
If Windows 7 is anything like Vista, you have to run the installs (eCabinets and updates) as Administrator and set the exe to always run as Administrator.
David Norton
Postby David Norton » Sat, Oct 31 2009, 2:47PM
Ok Dan, you got me. I am only one that uses this P/C, so I (assume) that I am administrator. If not how do I make sure programs install that way?
Should I uninstall Ecabs and reinstall? :wall:
Dave Norton
David Norton
Postby David Norton » Sat, Oct 31 2009, 3:13PM
Well I'll be dipped. I uninstalled the upgrade, then right-clicked and clicked on run as administrator. This time it took.
Thanks Dan :beer:
Dave Norton
Postby DanEpps » Sat, Oct 31 2009, 3:18PM
Starting with Vista, admin rights are removed from actual users so you have to explicitly tell programs to "run as administrator." Right-click on the installer file and choose "Run as Administrator." Do this for both the program and the update.
After installing, right-click on ecabinets.exe and set it to always run as administrator.
Here is a link to the post that describes the whole process: http://www.thermwood.com/forums/viewtopic.php?f=3&t=9294. Be sure to read the PDF from the link in that post.
Ah...I see you found it before I could finish my post. :beer:
David Norton
Postby David Norton » Sat, Oct 31 2009, 5:56PM
Everything is working fine now thanks again Dan!
Dave Norton
Users browsing this forum: No registered users and 42 guests
