Fake Paneled Doors
Bryan J Tanner
Company Name: Decor Designz
Fake Paneled Doors
Postby Bryan J Tanner » Sun, Nov 29 2009, 8:46PM
Hi we supply doors from a supplier that molds the MDF substrate and then laminates a vinyl to the front.
You can find them here http://www.arborlinedoors.co.nz
My questions is this, is there an easy way that I am overlooking to display a door or drawer in the style showen in the attached picture.
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
Re: Fake Paneled Doors
Postby Rick Palechuk » Sun, Nov 29 2009, 11:47PM
Bryan, You can take a Slab Door to the PE. There you can create tool paths to get the look your after. Here is a quick sample that I did in a few minutes.
tool paths.jpg (47.07 KiB) Viewed 4666 times
Postby George Davidson » Mon, Nov 30 2009, 12:21AM
When I need a door like that
I make the in door maker start with a slab then I bring in a DXF that I make in a Cad program.
or you can make it in e-cabinets
Rick you beat me to it
Door 17 x 32.jpg (33.93 KiB) Viewed 4664 times
Bryan J Tanner
Postby Bryan J Tanner » Mon, Nov 30 2009, 5:16AM
Thanks for that guys
I guess I was hopeing I'd missed something, and that there was a more automated way to do it.
Thanks again
HP Pavilion DV6
Postby George Davidson » Mon, Nov 30 2009, 7:46AM
I put your picture on a Display Cube make sure you check on (Stretch) that way it will fit the panel
I made a sheet good as Piha .75 x 48 x 96
I made a borad stock as Piha
Piha Cabinets.jpg (41.34 KiB) Viewed 4651 times
Bryan J Tanner
Postby Bryan J Tanner » Mon, Nov 30 2009, 1:06PM
Thats quite effective George!
HP Pavilion DV6
Paul Ford
Postby Paul Ford » Tue, Dec 01 2009, 12:12AM
Hey Bryan,
You could possibly talk to Arborline if your are a high user of there doors and ask them for a copy of the dxf for you to import into eCabinets?
I forget the guys name there now who I used to deal with, I think it was Andrew somebody? That way you can import it into the part editor...
Postby Rick Palechuk » Tue, Dec 01 2009, 12:27AM
What I'm wondering is can a formula be entered into the Constraints Manager which would allow the equal expansion or contraction of the field?
Bryan J Tanner
Postby Bryan J Tanner » Tue, Dec 01 2009, 4:37AM
Paul Ford wrote:You could possibly talk to Arborline if your are a high user of there doors and ask them for a copy of the dxf for you to import into eCabinets?
Hey thanks for that idea Paul. I'm over in Hamilton tommorrow, i might just call in and have a talk.
Rick Palechuk wrote:What I'm wondering is can a formula be entered into the Constraints Manager which would allow the equal expansion or contraction of the field?
Thats a good question Rick, i hope someone has an answer for us.
HP Pavilion DV6
Daniel Vonderheide
Postby Daniel Vonderheide » Tue, Dec 01 2009, 9:47AM
Yep, it can be done. not with just one formula though. The attached door is saved as a cabinet and is only a sample. You can see the depth difference in the profile cuts because it is a sample.
parametric door.hsf
sample door
(378.02 KiB) Downloaded 126 times
Postby Rick Palechuk » Tue, Dec 01 2009, 12:16PM
Thanks Daniel.
Jim Carter
Company Name: Jim Carter Corp.
Postby Jim Carter » Wed, Dec 02 2009, 7:33AM
good morning
I downloaded the file "parametric door.hsf" to see how it works. But I do not know how to open it in e cabinets.
the file shows up in the drawbox section, how ever the drawer box editor will not open it.
jim
jim@jimcartercorp.com
973-224-0221
Ringwood, New Jersey
Daniel Vonderheide
Postby Daniel Vonderheide » Wed, Dec 02 2009, 8:36AM
it's a cabinet file. You will need to save it in one of your cabinet directories and open it in the cabinet editor.
Jim Carter
Postby Jim Carter » Wed, Dec 02 2009, 9:23AM
thanks Daniel
so now I know, I can create almost any patern on a slab door as a parametric, attach it to a cabinet as an assembly. And be able to scale the assembly.
very cool.
Jim
973-224-0221
Jim Carter
Postby Jim Carter » Wed, Dec 02 2009, 9:35AM
OOOPS;
I think I was wrong, I can not scale the assembly.
973-224-0221
