Fake Paneled Doors
- Company Name: Decor Designz
Fake Paneled Doors
Hi we supply doors from a supplier that molds the MDF substrate and then laminates a vinyl to the front.
You can find them here http://www.arborlinedoors.co.nz
My questions is this, is there an easy way that I am overlooking to display a door or drawer in the style showen in the attached picture.
- Piha.jpg (8.95 KiB) Viewed 12009 times
HP Pavilion DV6
NVIDIA GeForce GT 230M
Windows 7 Home Premium
Re: Fake Paneled Doors
Bryan, You can take a Slab Door to the PE. There you can create tool paths to get the look your after. Here is a quick sample that I did in a few minutes.
- tool paths.jpg (47.07 KiB) Viewed 11996 times
When I need a door like that
I make the in door maker start with a slab then I bring in a DXF that I make in a Cad program.
or you can make it in e-cabinets
Rick you beat me to it
- Door 17 x 32.jpg (33.93 KiB) Viewed 11994 times
Thanks for that guys
I guess I was hopeing I'd missed something, and that there was a more automated way to do it.
Thanks again
Thanks again
HP Pavilion DV6
I put your picture on a Display Cube make sure you check on (Stretch) that way it will fit the panel
I made a sheet good as Piha .75 x 48 x 96
I made a borad stock as Piha
- Piha Cabinets.jpg (41.34 KiB) Viewed 11981 times
- Piha.jpg (7.71 KiB) Viewed 11981 times
- Piha_1.jpg (794 Bytes) Viewed 12066 times
Thats quite effective George!
HP Pavilion DV6
Hey Bryan,
You could possibly talk to Arborline if your are a high user of there doors and ask them for a copy of the dxf for you to import into eCabinets?
I forget the guys name there now who I used to deal with, I think it was Andrew somebody? That way you can import it into the part editor...
What I'm wondering is can a formula be entered into the Constraints Manager which would allow the equal expansion or contraction of the field?
Hey thanks for that idea Paul. I'm over in Hamilton tommorrow, i might just call in and have a talk.Paul Ford wrote: You could possibly talk to Arborline if your are a high user of there doors and ask them for a copy of the dxf for you to import into eCabinets?
Thats a good question Rick, i hope someone has an answer for us.Rick Palechuk wrote:What I'm wondering is can a formula be entered into the Constraints Manager which would allow the equal expansion or contraction of the field?
HP Pavilion DV6
Yep, it can be done. not with just one formula though. The attached door is saved as a cabinet and is only a sample. You can see the depth difference in the profile cuts because it is a sample.
- parametric door.hsf
- sample door
- (378.02 KiB) Downloaded 361 times
Thanks Daniel.
- Company Name: Jim Carter Corp.
good morning
I downloaded the file "parametric door.hsf" to see how it works. But I do not know how to open it in e cabinets.
the file shows up in the drawbox section, how ever the drawer box editor will not open it.
jim
jim
it's a cabinet file. You will need to save it in one of your cabinet directories and open it in the cabinet editor.
thanks Daniel
so now I know, I can create almost any patern on a slab door as a parametric, attach it to a cabinet as an assembly. And be able to scale the assembly.
very cool.
Jim
very cool.
Jim
OOOPS;
I think I was wrong, I can not scale the assembly.
