Hello
Can some one tell me why the holes for the hinge mounting plate are not applied to the corner cabinet side?
Jim
hardware holes in corner cab
- Company Name: Jim Carter Corp.
- corner angled front.hsf
- (576.02 KiB) Downloaded 238 times
Re: hardware holes in corner cab
Jim,
Increasing the depth of the holes should get them to show up on your cabinet. You'll have to play around with the entered depth to get the actual dilled depth that you're looking for. Once the holes do show up, the depth shown in the ecabinets nest diagrams should be the depth that you end up when you do drill them.
For one of my angled cabinets, I had to enter a drill depth of 18.96mm to get the holes to display, and drill at 9.5mm.
Thank you Nat:
I did it as you said.
JIm
JIm
