countertop question
Darren Harvey
countertop question
Postby Darren Harvey » Tue, Dec 15 2009, 7:39AM
good morning. i'm working in the layout section. i'm trying to place a counter top on my 2 cabinets. the problem is that i have 2 display panels on my left cabinet. and when i go into the counter top section they disappear. the display panels have been associated to the cabinet. but i' at a lost. how am i able to keep the display panel there because i need them in the final nest. thanks for your help, darren
ladd bath.esj
(1.64 MiB) Downloaded 44 times
Dennis Englert
Re: countertop question
Postby Dennis Englert » Tue, Dec 15 2009, 8:18AM
The Countertop Editor has no relationship with Display Panels. It will only display base cabinets.
Back in layout, go to the cutlist. The Display Panels should be listed.
If you need the countertops to extend to or beyond the display panels, you'll need to apply an overhang to the pertinant side or sides that have the panel installed. So you need to know/remember where the display panels are.
Dennis
Darren Harvey
Postby Darren Harvey » Tue, Dec 15 2009, 8:37AM
dennis, thank you for the reply. i got one more impossible question. is it possible to make a miter with puzzle joint? on a face frame. tuesday morning puzzler. thanks again, darren
Gary Puckett
Company Name: The Woodworkery
Postby Gary Puckett » Tue, Dec 15 2009, 8:38AM
Darrin,
Not sure why the display panel is not staying there, but they are showing up in the nest. So for putting a counter top on the project you are going to have to fill the empty corner with a cabinet make the counter top then delete the cabinet in the corner you made.
Dennis Englert
Postby Dennis Englert » Tue, Dec 15 2009, 8:45AM
Regarding the mitered puzzle joint: The only possibility that I can think of is by using the Part Editor to create all of the geometry, but that would be difficult and very time consuming.
My basic answer is no, but then there are some very astute users out there that can possibly change the settings in some fashion and alter the face frame. In the end though, the changes would be extensive and I think you'd end up making this into an assembly with the face frame as a separate cabinet.
Dennis
Darren Harvey
Postby Darren Harvey » Tue, Dec 15 2009, 9:27AM
dennis, thanks again. it was my puzzler for the day.
gary, the 2 base cabinets come together to make the 90degree corner. the display panels show up in the nest. it's in counter top construction. i need a 90degree, not a miter front. thanks for your all your help.
darren
Gary Puckett
Postby Gary Puckett » Tue, Dec 15 2009, 9:46AM
Darren here are the steps to take to construct a counter top. Because of the way I uploaded the last step shows up first .
View 3.jpg (11.57 KiB) Viewed 1790 times
View 2.jpg (25.68 KiB) Viewed 1790 times
View 1.jpg (22.49 KiB) Viewed 1790 times
Gary Puckett
Postby Gary Puckett » Tue, Dec 15 2009, 9:48AM
Then construct the counter top
View 4.jpg (9.24 KiB) Viewed 1790 times
Darren Harvey
Postby Darren Harvey » Tue, Dec 15 2009, 10:05AM
gary, that is what i finally ended up doing. i was just hoping i was missing something. thanks again for all your help, darren
Postby George Davidson » Tue, Dec 15 2009, 11:30PM
Here is one that I use for the corner
The way I look at it is do need to put studs on the walls to hold the counter top up right.
My corner stud cabinet can be resized
The corner 2-1/4"filler is a corner cabinet and the filler can be resized in to the left or right.
The right can be 6" W and the left can be 2" W
ladd bath_New.esj
(2.81 MiB) Downloaded 39 times
Postby George Davidson » Tue, Dec 15 2009, 11:36PM
My corner studs for the counter top
Darren Harvey
Postby Darren Harvey » Wed, Dec 16 2009, 6:48AM
thanks george. i guess i better stop thinking so hard, haha. i thank everybody all there help.
