placing 2 drawer fronts in wide cabinet w/ partition
John Vickerman
Postby John Vickerman » Fri, Dec 18 2009, 7:41AM
I have a wide face framed cabinet with a centered partition and a stretcher. Placing 2 inset drawer fronts, I am able to place one but not a second, how do you place it?
I could place a double door but this would create problems with hardware holes.
thank you in advance. :wall:
JohnLashuay
Re: placing 2 drawer fronts in wide cabinet w/ partition
Postby JohnLashuay » Fri, Dec 18 2009, 8:45AM
John,
Post the cabinet and we'll take a look at it.
http://www.rylexonline.com
Thermwood CS 43
Postby George Davidson » Fri, Dec 18 2009, 12:48PM
I set the right one but I can not set the left. My computer freezes up.I know it's going to snow Sat. here but why the computer is freezes up today :?:
Freeze Up drawer-2_11.jpg (74.36 KiB) Viewed 1629 times
John J. Desmond
Company Name: Wood Designs Unlimited
Postby John J. Desmond » Fri, Dec 18 2009, 7:45PM
John,
Is this what you are trying to do? If so, I just placed the drawers in drawer box editor.
Sample Cab..jpg (51.05 KiB) Viewed 1606 times
Sample Cab2.jpg (67.19 KiB) Viewed 1606 times
John D.
Custom Furniture & Cabinets
http://wooddesignsunlimited.com
John J. Desmond
Postby John J. Desmond » Fri, Dec 18 2009, 8:47PM
John,
Here is another one I did with placing two display boards as drawer fronts.
Sample Cab 3.jpg (66.67 KiB) Viewed 1600 times
You can take it to part editor to put an edge on it if you want.
John
John Vickerman
Postby John Vickerman » Sat, Dec 19 2009, 6:10AM
Here is the cabinet, it does not make sense that I would need to use a display board, If I could create a double door, a double drawer front would be a nice option also.
test.hsf
(498.02 KiB) Downloaded 53 times
Postby George Davidson » Sat, Dec 19 2009, 1:20PM
The opening is on top right under the top it is about a 1/8"
Test-2_12-19-09.hsf
(542.02 KiB) Downloaded 47 times
John Vickerman
Postby John Vickerman » Sun, Dec 20 2009, 6:30PM
George, I am not able to highlight the area, there is a partition and when setting the first drawer front the right side reveal is 1/2 the opening minus 1/16.
If I place a double door there and then a drawer box my hardware holes would not be correct.
I most likely am missing something quite simple.
JV
Postby Rick Palechuk » Sun, Dec 20 2009, 11:51PM
John, if you hilite the opening and add a mid stile, you can then add two separate fronts. Adjust your mid stile to 1/32" in width, and adjust your gaps for correct clearance and it should show properly. Note: Make your Mid Stile from a different material like DNC so it doesn't confuse your cut-list. Also watch your Drawer box side clearances. HTH.
test 2.hsf
(520.02 KiB) Downloaded 50 times
test 2.jpg (18.23 KiB) Viewed 1592 times
John Vickerman
Postby John Vickerman » Mon, Dec 21 2009, 12:48PM
Rick, I considered this and will try it now, sure enough it works, I will need to try the same thing with a euro style cabinet.
Thank you, John Vickerman
