V6 will not save size changes on my seed cabinets
brian haughey
Company Name: bh woodworking
Post by brian haughey »
changing heights on my seed cabinets (for bath) from 30.5 to 34.5"
i open each cabinet in CE and change height. Click on save cabinet which it ask me if it want to overwrite existing file to which i click yes.
BUT THEN WHEN I OPEN SEED CABINET FILE AGAIN IT IS BACK TO ORIGINAL HEIGHT.
ANY IDEAS?
btw; IF I DECIDE TO SWITCH BACK TO v5, CAN I ONLY USE THAT UNTIL MARCH?
Scott G Vaal
Re: V6 will not save size changes on my seed cabinets
Post by Scott G Vaal »
Brian,
It sounds like you are loading your cabinets from the old data path structure, saving into the new, then reloading from the old again. We allow you to load from anywhere, but you can only save in the User Data Path. By default this path will be:
for XP: C:\Documents and Settings\All Users\Documents\Thermwood\eCabinet Systems\cabinets
For Vista/Win7: C:\Users\Public\Documents\Thermwood\eCabinet Systems\cabinets
Look for your saved cabinets here.
Joe Dusel
Post by Joe Dusel »
Dumb question for you. When you change the Height field are you pressing Enter to actually cause the height to change? If not you have not actually changed anything.
Joe
CFT411 http://www.cft411.com
jason galbraith
Country: AUSTRALIA
Post by jason galbraith »
I would say that what Scott has said is the problem, I noticed this when i created a new cab and saved it to seeds in my original directory, and then couldn't find it when i opened my seeds folder. The new version (for whatever reason i do not understand) saves cabinets in a different directory.
www.eastcoastultimate.com.au
Rick Deskins
Company Name: Thermwood
Post by Rick Deskins »
jason galbraith wrote:I would say that what Scott has said is the problem, I noticed this when i created a new cab and saved it to seeds in my original directory, and then couldn't find it when i opened my seeds folder. The new version (for whatever reason i do not understand) saves cabinets in a different directory.
This has been listed and fixed in the next update.
Rick Deskins
eCabinet Systems Programmer
