Grass Zargen Drawer Slide Hole Patterns
Jon Kenworthy
Company Name: darrells Carpenter Shop
Postby Jon Kenworthy » Wed, Jan 27 2010, 1:14PM
Does anyone understand the numbering in the Hardware Hole Editor Standard Patterns for the Grass Zargen Drawer Slides? The 4 5/8" height to the 8 3/8" height have corresponding numbers in the Standard Patterns (22700 - 22911) then it jumps up to 30926 and higher. I am guessing these must be for the 1 11/16" height and the 3 3/8" height but I can't figure it out.
Michael S Murray
Re: Grass Zargen Drawer Slide Hole Patterns
Postby Michael S Murray » Thu, Jan 28 2010, 9:53AM
Hi Jon,
I never whipped the software where Zargens are concerned. What I ended up doing was building a library of the different configurations I needed and used the part editor to place the holes I needed. If you follow grass kiss system it actually will begin to make since after a while. What I do is keep all the different size sides I need with the line drilling holes, and then I choose the holes I need for whatever cabinet config. and then put those holes only in the actual cabinet. Simple way for simple mind!!!
Mike Murray
mike@versatilecabinet.com
Jon Kenworthy
Postby Jon Kenworthy » Thu, Jan 28 2010, 12:36PM
Thanks, Mike. Simple is good.
Jon
Users browsing this forum: No registered users and 7 guests
