Where is the "Hardware Selection" button
Trying to add pulls. When I try to "Add/Locate Pulls", I get a message that says "No Drawer Pull Selected! A Drawer Pull must first be selected via the 'Hardware Selection' button before a pull can be Added/Located." Where is this "Hardware Selection" button?
Dan Calvert
- Company Name: Calvert Custom Cabinetry
Re: Where is the "Hardware Selection" button
From the Door/Drawer Editor move your cursor to the right side of the window and select the pulls tab. Now from the list of manufactures select the pull that you are wanting and press the select button at the bottom of the window. Now select the door or drawer you want the pull to be attached to and select the Add/Locate Pulls button. Next indicate where you want the pull to be place on the door or drawer and press OK.
That's what I've been doing with no success. I'm using pulls that supported a 3d image in the last version, but they just don't show up. Is it possible I need a different pull?
