Eclipse DXF file ?
Dale Wills
Company Name: none
Country: AUSTRALIA
Eclipse DXF file ?
Postby Dale Wills » Wed, May 05 2010, 8:15PM
Hi,
I have created an eclipse in AutoCad and want to load it into eCabs to apply to a part. The arc of the eclipse comes out in eCabs as a series of short straight lines to form the arc and not a nice curved arc. In AutoCad it's definately a smooth shaped eclispe but once loading in eCabs it's different. Can anyone shed some light on this problem?
Dale
Eclipse.hsf
(316.02 KiB) Downloaded 67 times
Re: Eclipse DXF file ?
Postby Kerry Fullington » Wed, May 05 2010, 8:29PM
Dale,
I could be wrong but I think it is the Cad program that draws curves as segments. I know in Intellicad I can choose how many segments. The more segments the smoother the curve looks but a bunch of segments really bogs eCabinets down.
You can use the Tesselation setting in eCabinets to smooth the lines.
Kenneth Rychlik
Postby Kenneth Rychlik » Wed, May 05 2010, 8:56PM
I agree, it's an autocad thing.
If you pm me with your email and tell me what size you need, i will make you one and email the dxf to you.
Kenneth
Sean Jakob
Company Name: Sean Jakob Cabinets
Postby Sean Jakob » Fri, May 07 2010, 3:43PM
Dale
Have you actually tried to cut it anyway?
I have seen things like this in the past with a variety of other systems and sometimes despite the graphics, they actually do cut properly.
Would you let me know.
Dale Wills
Company Name: none
Country: AUSTRALIA
Postby Dale Wills » Fri, May 07 2010, 8:24PM
Sean,
Initially I also thought it was simply a graphical thing and did do a test cut just in case. The test piece came out as represented by the graphical display in eCabs and was a series of approx. 100mm long straight lines formed in an arc to create the eclipse. Kenneth was nice enough to create the eclipse for me in an alternative CAD program he uses and it has since cut perfectly. I'm sure I could tweak my AutoCad settings to get it to work myself next time. It is an eclipse shaped benchtop template for the construction company we are doing a job for. They are using it to shoot lines up to the ceiling to create a drop down bulkhead to match the benchtop below.
Dale
jason galbraith
Country: AUSTRALIA
Postby jason galbraith » Sun, May 09 2010, 5:12PM
Elipse? :P
www.eastcoastultimate.com.au
Postby Forrest Chapman » Sun, May 09 2010, 9:09PM
Maybe Thermwood guys can weight in on why most cabinet design programs including ecabinets do not have the ability to do an elipse. Is it that much more difficult to program than an arch?
Matt Snowball
Postby Matt Snowball » Mon, May 10 2010, 3:46AM
it's 'Ellipse' actually .
Kenneth Rychlik
Postby Kenneth Rychlik » Mon, May 10 2010, 7:23AM
Give it a rest guys. I knew it was not speellled correctly as well.
However, I knew what he meant and helped him out. Isn't that enough?
Kenneth
Tom Goodman
Company Name: Stephenson Millwork
Postby Tom Goodman » Fri, May 21 2010, 11:25AM
Hello, In Autocad, an ellipse is composed of short arc segments that can not be exploded. An elliptical arc can be exploded but you wind up with LOTS of small arcs. We do a fair amount of elliptical transoms for fancy entrances. To run the elliptical pattern on our point to point, we have to change the ellipse to arcs. We have developed a little DOS program to approximate the elliptical shape with 2 radii. There may be some others on the web. Let me know and I'll send you a copy. Technically, an ellipse is an isometric circle. If you were to slice a cylinder at an angle (not 90) the resulting shape would be a true ellipse.
Best,
Tom Goodman
Will Williamson
Postby Will Williamson » Fri, May 21 2010, 2:30PM
When you export a DXF from Corel Draw it produces a smooth Ellipse. I spent a lot of time on this same problem. I never did solve it in Auto Cad.
Will
http://www.willmade.com
Dale Wills
Company Name: none
Country: AUSTRALIA
Postby Dale Wills » Mon, May 24 2010, 5:05AM
Hi,
Thanks for your input guys. I found that there is a setting in AutoCad that you can alter how 'ellipses' are created. By default AutoCad creates an ellipse as a 'true ellipse object' but you can elect to create them also as polyline representations of an ellipse which works as expected when importing into eCabs. For those using AutoCad and want to try this, type pellipse and then enter 1.
Dale
Users browsing this forum: Google [Bot] and 7 guests
