Angled Cabinet Help
Kevin Dunn
Company Name: Castle Works
Angled Cabinet Help
Postby Kevin Dunn » Thu, Jun 03 2010, 1:14PM
New to eCab and am trying to create an angled cabinet.
I was able successfully angle the deck, but not certain how to rotate / angle the face frame and door to match. See attached picture.
If anyone can point me in the right direction, I would appreciate it
Kevin
Ryan Callahan
Re: Angled Cabinet Help
Postby Ryan Callahan » Thu, Jun 03 2010, 2:18PM
Kevin,
I think if you start with a Std Base Corner cabinet, then play with the multiple settings, you will be able to achieve your goal.
Once you select the corner as your seed, notice the blue arrow under Cabinet Edit. This will give you the options for setting any of the base dimensions. Be sure to go to Construction Settings and set the Corner Settings Tab to Angled Front.
Hope this helps you get under way.
Good luck.
Ryan Callahan
Thermwood
Kevin Dunn
Postby Kevin Dunn » Thu, Jun 03 2010, 2:30PM
I tried starting w a corner cabinet and change the settings you indicated. I had a lot of trouble with this approach, as it kept telling me it would result in an unstable cabinet and would not make the changes.
Kevin Dunn
Postby Kevin Dunn » Thu, Jun 03 2010, 2:47PM
I tried your suggestion again, and had a little better luck with it...certainly a lot closer to what I am after. I think the difference was the construction settings which I had not previously changed.
Thanks for the help.
Kevin
Users browsing this forum: Google [Bot], Ralph Balanik and 9 guests
