Hi all,
I've searched the forum for angled cabinet and can't find the answer.
I need to create a cabinet for under a stairs if possible.
For example I need a cabinet that when you look at the face of it has a 2000mm lefthand gable and a 1500mm righthand gable with top and back to match.
I can make it up out of display parts but would prefer to use a cabinet.
Thanks for you help.
Conor
Angled cabinet
Re: Angled cabinet
Hi Conor. You can do it using a combination of a cabinet and a display panel. You will have to size a cab to the maximum hight required and then in the cabinet editor give the one side a top inset to bring it down to the correct hight. You will have to delete the top and use a display panel instead which you can rotate to the correct angle. The size for this panel can be obtained by usinig the measurement tool in the cabinet editor. The doors and the backer can also be edited in the part editor to display the correct slope and be cut correctly if it is going to CNC. Does this make any sense?
Re: Angled cabinet
Thanks Nick.
