Error Opening StringTable.mdb
Ron Sloan
Company Name: Wine Country Custom Carving
Postby Ron Sloan » Thu, Jul 15 2010, 6:44PM
After installing v6, build 4, I get an error on startup that StringTable.mdb cannot be opened. I noticed that it moved this file from the application folder in the earlier versions into the All User app data folder. I checked, and everything appears to be there. I even tried uninstalling, installing an earlier version (5.2) then upgrading: same issue. I've check the permissions on the mdb file and they look OK. I've also tried logged in as administrator. I've e-mailed Thermwood, but no response, yet.
Any ideas?
Ron
Re: Error Opening StringTable.mdb
Postby Kerry Fullington » Fri, Jul 16 2010, 6:51AM
Ron,
Do a search of "String Table" and there are several threads about this.
Be sure to save the upgrade to your desktop and run it from there.
Ron Sloan
Postby Ron Sloan » Fri, Jul 16 2010, 11:03AM
Thanks Kerry,
A search was the first thing I tried, and I got a few more hits searching for "string table" instead of stringtable.mdb. I've pretty much tried all the suggestions, except to run the eCabUpdate.exe from the program directory, since this file apparently runs the 5.2 build 5 version, and I have v6 build 4 installed. I have even tried uninstalling everything, and installing v5, then upgrading and also uninstall followed by fresh install of v6. One question - Is it important to save the file to the desktop, instead of any other directory, before running? I always save my downloads before running. I also tried the Microsoft Installer Cleanup tool - It had both versions listed, so I used it to clean the v5 build...
Ron
Postby Kerry Fullington » Fri, Jul 16 2010, 11:19AM
Just save the file to your computer, not necessarily the desktop.
Give Thermwood a call. They will get you running.
Users browsing this forum: No registered users and 15 guests
