Am I just confused, or should the select molding button not be below the add top/middle/lower molding buttons in the molding editor. I tried downloading and re-installing the latest build. Still not there. Maybe I'm just not looking in the right area.... I rarely change the mouldings that I have associated to each cabinet from my library, but this one has none so I need to add it....
Also wont let me add fixed shelfs in this cabinet. I get the 'change resulted in unworkable top' error. Adding adjustable shelf works fine.
no select molding button?
- moulding editor09.jpg (91.9 KiB) Viewed 5857 times
- Company Name: Thermwood
Re: no select molding button?
Molding selection is now in the item window (right hand of screen). Can you post the cabinet that will not add the fixed shelf?
Rick Deskins
eCabinet Systems Programmer
Thanks Rick.... Thought it might just be me...
Here is the cabinet that wont take fixed shelfs, now with moulding!
- 45 End unit 14w.hsf
- (400.02 KiB) Downloaded 361 times
The front inset setting for fixed shelves is too large. If you lower this setting, you can get it to work.
Rick Deskins
Cool,
Thanks again.
Thanks again.
