hi all
we are tying to build a shop counter and getting stuck here this cabinet has got 3 sections in which we want to have drawers on the both end sections and doors in the middle section but where as in the door and drawer selection it is selecting all the space as a single section where are we going wrong pls advice
thanks to all
mohan
not able to put doors and drawers here
- Country: AUSTRALIA
Re: not able to put doors and drawers here
Mohan,
This happens to be glitch that you have discovered. We will have this resolved for the next version. It is the edge banding on the top edges of the partitions causing this issue. So, until the next version, you can get around this anomaly by removing the edge banding from the top edges of the partitions, add your doors and drawers the way you need them, then add the banding back to the top edges. Thanks for the post.
Thank you both, I encountered the same problem but couldn't nail down what the cause was
