I can't dimension from a node on anything (cabinet, wall, assembly) to a wall item (ie: water pipe). Is it possible to do this, or am I having bugses? I need to find the dimension from a water pipe to the inside of a cabinet, so I can design the drawer to fit around it.
Thanks - Jason
P.s. great - the jpg doesn't show the leader with arrows pointing to the side of cabinet and water pipe. I suppose that's for another post....
Is it me, or LDE?
Is it me, or LDE?
- how.jpg (20.07 KiB) Viewed 2460 times
www.appleboxwood.com
Re: Is it me, or LDE?
Jason,
This is not a bug. Markers for those items just never have been implemented. The only "Wall Items" that show markers in the Line Drawing Editor are Doors and Windows. I will put this on the wish list for future implementation. For now, you can add a Display Cube on the wall to represent your water pipe, etc. The display cube will show the corner markers for you to dimension off of. Hope this helps.
Sounds good Scott, thanks much - Jason.
