Where is the face frame
I need to show a raised panel bar front, so I took a cabinet and eliminated all the parts except the face frame. When I go to put it in the room the face frame will not show up. But if you put the mouse arrow where it should be it says it's there.
Any Ideas
Any Ideas
Re: Where is the face frame
Gary,
Post the job.
Post the job.
Kerry,
I tried 3 times to post the job. If you want I can try to email it to you.
If I save it as an assembly it will show up.
It is loading as we speak, don't make fun of all the lights I tend to get a little carried away.
Gary,
I haven't seen your job yet but your last statement tells me what it is. Take out some of the lights. George Davidson had a similar problem and it was because too many lights.
Remove lights till your face frame appears.
Gary,
I never received your email. Did removing some of the lights fix the problem?
Kerry,
I will try and send it again. I removed all the lights and it still did not show up as a cabinet.
Gary,
Have you tried re-starting windows and eCabinets. Everything shows up for me in custom layout and in presentation view.
Kerry,
I had to save them as an assembly, thats why they are showing up.They will not show up if you save it as a cabinet.
Gary,
I see what you mean. I would build another cabinet from scratch. It appears that something must have been corrupted in your cabinet file. I have some panel cabinets done the same way and don't have a problem.
It could be that the cabinet you built the face frame from is corrupt.
Kerry,
I tried it again with a new cabinet and still no show. I then made a new job with a new wall, tried it and still no show.
I am trying to cover the complete long wall so my cabinet is over 120" and 42 " high. Do you think that is the problem?
Gary,
Try the attached cabinet. If it works you will have to change to the door you wee using for the panel.
- wainscot.hsf
- (166.02 KiB) Downloaded 276 times
I tried a tall framed cab, with just the face frame Deep at 24",12",3/4" and each one in custom layout. Each one shut down my e-Cabinet program
I have to go today is our grandson's birthday the big 3.
3 weeks ago my son had to give a way some of Michael's toys so they would have room for his new toys?
Kerry,
This is what I get when I open your hsf file
