Huge problems with Ecab version 6 build 6
DanFecteau
Post by DanFecteau »
I have been having problems with ecab for about a month or so and I don't know why. I load cabinet that I already worked with and I try to do simple things such as changing width and the program is very slow and when it finally get done the door disapear and all kind of other problems....Has anybody been having those kind of problems ??
Thank you.
JohnLashuay
Re: Huge problems with Ecab version 6 build 6
Post by JohnLashuay »
Dan, V6 B6 has been working great for me! Haven't really had any major issues like what you are talking about. It seems as though some others have had some weird issues and they rebooted and the issues have gone away.
Have you been able reproduce the problems?
-John
http://www.rylexonline.com
Thermwood CS 43
DanFecteau
What do you mean by reboot ? Only restart computer ?
JohnLashuay
DanFecteau wrote:What do you mean by reboot ? Only restart computer ?
Yes, either just restarting Ecabinets or fully restarting your PC.
Thermwood CS 43
Scott G Vaal
Post by Scott G Vaal »
Dan,
Something you can try... Seems that some (probably most) of the virus protection softwares can be way too restrictive/picky by default and can cause slow downs and other quirks. If your virus protection allows it, try to exclude the AppData path and the UserData path and also the ecabinets.exe file, if it allows exclusions at that level, and see if that helps.
The AppData path to exclude is:
For XP:---------- { C:\Documents and Settings\All Users\Application Data\Thermwood }
For Vista/Win7: { C:\Users\ProgramData\Thermwood }
The default UserData path to exclude is (if you changed it, then use what you have set instead):
For XP:-----------{ C:\Documents and Settings\All Users\(shared)Documents\Thermwood\eCabinet Systems }
For Vista/Win7: { C:\Users\Public\(public)Documents\Thermwood\eCabinet Systems }
DanFecteau
Thank you Scott it seems to have fixed the problems.
DanFecteau
Problems are back....
