Need to draw steps
Gary Puckett
Company Name: The Woodworkery
Need to draw steps
Postby Gary Puckett » Thu, Jan 20 2011, 8:53AM
I am putting a bathroom in a basement and need to show the steps leading down to the basement. Does anyone have an idea on how to draw some steps?
I am using the drawing to submit for the permit.
Rob Davis
Re: Need to draw steps
Postby Rob Davis » Thu, Jan 20 2011, 9:20AM
Gary, could you once again use the cabient as a building block for everything and make the bottom step a 36" wide x 6" tall x 8"deep cabinet, then 2nd step be a 36 x 12 x 8, 3rd step is 36 x 18 x 8, and so on, stacking them up to build a stairway?
Just a thought.
Rob
Postby Kerry Fullington » Thu, Jan 20 2011, 9:20AM
Use a display cube. You can get as detailed as you wish.
Here is one I did several versions back the way Rob describes.
Postby Kerry Fullington » Thu, Jan 20 2011, 9:30AM
Gary,
You could actually use a display board to cut your stringer then copy and paste,
use a display board to cut and profile your treads and risers then copy and paste and you would have a cut list.
Postby George Davidson » Thu, Jan 20 2011, 9:34AM
Stairs Plan
You will need to resizes them to what you want
Steps STL with railing.zip
(9.17 KiB) Downloaded 144 times
Gary Puckett
Postby Gary Puckett » Thu, Jan 20 2011, 9:46AM
Thanks for the quick reply.
