Ecab deleting cabinets from job
Aaron Roberts
Company Name: Kensington Cabinets
Postby Aaron Roberts » Wed, Feb 09 2011, 5:15PM
After nest my job and sending to the CNC router, several cabinets disappeared. When I try to add them back they just replace other existing cabinets instead of making a new cabinet at the end of the list. I've tried restarting several times and starting new files. Same thing every time. Anyone have any suggestions?
Aaron
Kensington Cabinets Ltd.
Sechelt, BC, Canada
http://kensingtoncabinets.com/
jason galbraith
Country: AUSTRALIA
Re: Ecab deleting cabinets from job
Postby jason galbraith » Wed, Feb 09 2011, 8:16PM
I too have had this happen to me. Also ,yesterday, ecabs locked up on me whilst putting a shelf in a cabinet. After restarting, it had deleted all cabinets from the job and left only panels.
www.eastcoastultimate.com.au
Aaron Roberts
Postby Aaron Roberts » Thu, Feb 10 2011, 10:49AM
some more details on the error.
The issue occurs on ecabinet only. As the system is finishing exporting the .twd file the screen flashes blank (as it normally does) but when it appears all of the upper cabinets are missing. I’ve tried using upper cabinets from difference seeds and get the same result. I’ve saved the file under multiple names prior to exporting to .twd file and all the upper are deleted from all files after the export. The .twd file itself seems fine. I can see all the cabinets are there, the problem is only on ecabinets and does not effect control nest. I had made no changes or updates to ecabinets. There were background windows updates however. Currently running windows professional xp.
Sechelt, BC, Canada
Jocelyne Letarte
Company Name: portes PaJo s.e.n.c.
Postby Jocelyne Letarte » Thu, Mar 10 2011, 1:18PM
J'ai le même problème... Y-a-t-il quelqu'un chez Thermwood pour résoudre le problème?
Merci de répondre...
Jocelyne L.
www.porrtespajo.com
Bev Brown
Postby Bev Brown » Thu, Mar 17 2011, 12:12PM
Hi,
I don't speak French, Jocelyne, but maybe if you try saving and restarting the program more often that will help.
Bev
BJB
Postby DanEpps » Thu, Mar 17 2011, 8:55PM
It says "I have the same problem... Y-a-t-il someone at Thermwood to solve the problem?" I have no idea what "Y-a-t-il " means.
Jean-Gabriel, where are you???
Postby Forrest Chapman » Fri, Mar 18 2011, 8:08AM
Dan it sounds a little like "yall tell". Maybe they are southern french.
Postby DanEpps » Fri, Mar 18 2011, 9:14AM
Forrest Chapman wrote:Dan it sounds a little like "yall tell". Maybe they are southern french.
You might have something there. LOL
Brad McIntosh
Company Name: CNC Automation
Postby Brad McIntosh » Fri, Mar 18 2011, 1:04PM
Gentlemen,
You almost have it...
I have the same problem... Is there someone at Thermwood that can solve the problem?
Jocelyne is a CNC Automation client (has a couple of 53s and uses Panelmetrix along with eCabinet Systems). Aaron is also a CNC Automation client from British Columbia.
We could chalk it up to "a Canada thing", but Jason Galbraith appears to hail from Australia.
Any suggests or input from a Thermwood representative?
Thanks in advance,
Brad McIntosh
CNC Automation
Twitter: @bmcncautomation
Postby DanEpps » Fri, Mar 18 2011, 6:54PM
Brad McIntosh wrote:...Jocelyne is a CNC Automation...
Hmmm...sounds like your problem then Brad. :wink:
Users browsing this forum: No registered users and 39 guests
