Corner Cab Bug
Wally Schneeberger
Corner Cab Bug
Postby Wally Schneeberger » Thu, Nov 24 2011, 10:42AM
Here is a cabinet that I changed the corner settings on and it shows the change but when I take the top to PE it still shows a mitered corner and I cannot do what I wanted to do -- 7.5" x 7.5" corner cutout.
f&g.hsf
(410.02 KiB) Downloaded 88 times
Re: Corner Cab Bug
Postby Kerry Fullington » Sat, Nov 26 2011, 9:23AM
Wally,
Your cabinet seems to work as it should.
Are you talking about the miter on the front of the cabinet or the back?
Wally Schneeberger
Re: Corner Cab Bug
Postby Wally Schneeberger » Sun, Nov 27 2011, 9:52AM
At the back Kerry-- I don't want any miter there but it keeps it even when I change it. I want a square of 7.5" cut from the corner (to go around a post) not a miter.
Re: Corner Cab Bug
Postby George Davidson » Sun, Nov 27 2011, 11:25AM
Hi Wally
Is this what you are looking for
Corner Cab_11-25-11.hsf
(808.02 KiB) Downloaded 80 times
Re: Corner Cab Bug
Postby Kerry Fullington » Sun, Nov 27 2011, 11:43AM
Wally,
Your cabinet works fine for me.
Try opening the cabinet in the cab editor then right click and choose Remove Part Editor Cuts/From Entire Cabinet and let the cabinet re-generate and see if you can get it to work in the part editor.
Re: Corner Cab Bug
Postby George Davidson » Sun, Nov 27 2011, 11:55AM
Here is one for you Kerry
I will have to try that
Corner Cab with Pipes_11-27-11.esa
(908.02 KiB) Downloaded 98 times
Wally Schneeberger
Re: Corner Cab Bug
Postby Wally Schneeberger » Sun, Nov 27 2011, 8:23PM
George Davidson wrote:Hi Wally
That's it George -- I guess I will have to regenerate it like Kerry advises to get it right.
Thanks George.
Wally Schneeberger
Re: Corner Cab Bug
Postby Wally Schneeberger » Sun, Nov 27 2011, 8:24PM
Kerry Fullington wrote:Wally,
Thanks Kerry - I must have lingering PE cuts.
