Ken,
After some time away from the software, I'm trying to intialize andother instance of V5 on a laptop, after I had installed the same license on my desktop.
The software error message I receive basically states that I cannot use the code to initialize an instance of the software if its already been installed on antoher machine.
I see now that i am also two versions behind w/ V5. Can you help me understand the bets way to:
1. Get current w/ the software, (download or disk?)?
2. Intialize a copy on my laptop so I can work on the train?
Thanks in advacne for your for your valued reply.
CPS
Registration Code already used
Re: Registration Codes may not be Shared
Christopher,
You can download the software at the following link:
http://www.ecabinetsystems.com/ecabinet ... es_ref.htm
You can use the online registration code generator to get another code at this link:
http://order.ecabinetsystems.com/ecabfo ... ubmit.aspx
Hope this helps,
Hope this helps,
