Conestoga doors not sizing correct on corner framed base cab
Select the std corner framed base cabinet from the standard cabinets directory go to door editor select Conestoga crp-10 change the profile from machine edge to any other profile. Set as default. Construction settings are:Hing side overlap 1/2",Openside overlap 1/2",Top overlap 1/2",Bottom Overlap 1/2",Double door gap 1/8", Door inset 0". Add the Lazy suzan doors. See the extra gap where the doors meet. I have to adjust the double door gap to a negative value to get the doors to size properly It does not do this with the machine edge profile.Is this the way that these type of doors have to be handled or is it a bug?
Re: Conestoga doors not sizing correct on corner framed base
After taking a closer look at the doors they are sizing properly it is the profile that is giving the elusion of the extra gap
