drawer box front for pull-outs
Anyone having a problem in CN with the fronts of pull-out type drawers? (Pantry) We put a 3 point arch in the top of the front panel for a finger pull kind-a-look never had a problem, now CN shows a full circle... of course it goes off the table so were getting an X axis out of bounds?
Anyone else get this
Thanks chris
Thanks chris
Re: drawer box front for pull-outs
Hi Chris, I haven't seen anything like this.
Can you post the cabinet?
-John
-John
- Company Name: Thermwood
Can you post the cabinet file this twd was made with?
Rick Deskins
Well I wish I could. I tried to upload the CNC File and the TWD file but these Extensions are not allowed??
Chris
Chris
- Josh Rayburn
Chris,
You can change the extentions to .txt and post them or zip them then post.
Chris,
We really need the ecabinets file. The twd/cnc files will show the problem, but it will not helps us tell you why you have the problem or how you might be able to fix it. Please post the ecabinet file.
Rick
Rick
Rick Deskins
I thought ecabinets file was a TWD created by ecabinets? So I am not sure what or how I get you what you need.
Chris
Chris
I need either the ecabinets job file (ESJ), cabinet file (HSF), or asssembly file (ESA) that was used to create the twd file.
Rick Deskins
Hope this works
- Draws.jpg (7.75 KiB) Viewed 19078 times
- Draws.esa
- (1.68 MiB) Downloaded 953 times
Well, I tested your file going out to control nesting and all worked for me. So, there must be a setting on your control nesting that would produce this. I will need to get the export from your control nesting. Go to control nesting and load the twd you are having problem with. the go to file->Export and save off the export file. It will be a *.cab file. Then post that and hopefully we can find the root of your problem.
Rick Deskins
???? << Go to control nesting and load the twd you are having problem with. the go to file->Export>>>???
Okay, Load file, bottom of screen F5 (File) there is no export button? I can save a file (F2) but it is the CNC file.
$&*(^*)_(@#.... MONDAY MORNING!!!
Here Ya Go.
Here Ya Go.
Well it wont allow the .cab extension
Can you email the cab file to cabinets@thermwood.com?
Rick Deskins
