problem with drawer box
Jason Stephenson
Company Name: Marks Joinery
Postby Jason Stephenson » Wed, Jun 06 2012, 12:27AM
I have an issue with draw boxes i have got a draw that has costraints on it and edged banding associated to it which is saved under draw boxes but when i go to add draw boxes the default box that comes up is what it is saved under and has no constraints and no edge banding associated to the draw at all, there fore when i go and cross the draw box that is set as default off and click on the same box that all the holes and edge tape are associated to the box. i am a little bit confused on where i have gone wrong? I release that it is probably an easy fix but it is leaving me a littlke frustrated! thanks Jason
Scott G Vaal
Re: problem with drawer box
Postby Scott G Vaal » Wed, Jun 06 2012, 2:11PM
Jason,
Make sure that you are selecting the drawer box via the {Drawer Box Selection} button in either the Door/Drawer Editor or in the Drawer Box Editor, and set it default. It should then be the box that you set. You may try setting it to something totally different, like one of the standard boxes, and see if it is changing it for you. Hope this helps...
Users browsing this forum: No registered users and 28 guests
