Door panels from sheet goods and nesting
- Company Name: Frank Shannon Designs
Does eCabinet support plywood for door panels. If so what about a nesting diagram for the panels?
It does it for drawer bottoms so I was just wondering. Thought I'd ask before giving up.
- Scott Marshburn
Re: Door panels from sheet goods and nesting
Sorry Frank unless I am mistaken ECabinets only allows a board stock to be selected for door panels for there five piece doors. It will however create a cut list that you could get the panel sizes from and then you could use a cabinet with every thing deleted except for the back then resize and batch.
- Company Name: westone-group.com
- Country: UNITED KINGDOM
I have just looked at this and it does (thank good) go to Door/Drawer front designer
then (i am looking at the Thermwood standard door2) click on "Details for Cut List" then you set panel details there.
Simon
Simon
That's what I do. I use a bottom so that I get a good representation in the plan of the job window. Maybe someday.
For what it's worth, I haven't found this in any other cabinet package either, at any price. They give a drawing and a cut list which is fine as far as it goes. But if you 45 doors and drawer fronts it can come to several expensive sheets. I used kirei for some doors and it was almost $300 a sheet for 36x72x19mm sheets. Way more expensive than a panel made from domestic hardwood. You better believe I was looking for a nesting diagram.
sorry for that but all i will be doing is adding the sheet's of ply in as board (as even if I was using a CNC it should still work).
Simon
Simon
is it a plan shaker door you are looking for with like 6mm ply centre panel (flat both side's) and H/wood frame?
Simon
Simon
- Scott Marshburn
Simon Ecabinets will not nest board stock it has to be a sheet stock in order to nest.Simon Randall wrote:sorry for that but all i will be doing is adding the sheet's of ply in as board (as even if I was using a CNC it should still work).
I have a solution of sorts.
First, create an edgebanding that is the width of your stile minus the depth you want the panel to go into the grove. For instance, say you have a 3" stile with a 1/2" groove for the panel and you want the panel to go 7/16" into the groove. Make the thickness of your edgebanding 2 9/16".
The set up a slab door with the panel material you want and use your new wide edgebanding stock.
Slab doors DO produce a nest as well as a cut list. So you'll get a nest of your door panels.
There's one obvious and pretty big limitation to this method. The rails and stiles have to be the same width. But it's a something anyway.
Yes, just a plain door.Simon Randall wrote:is it a plan shaker door you are looking for with like 6mm ply centre panel (flat both side's) and H/wood frame?
- John J. Desmond
- Company Name: American Millwork Company
I use display panel. I type in each panel. I added 1/4" material size in 4x8 sheet. I enter each panel and it nests it for me that way. I just cut from the print outs. It takes a bit longer but it gives me the exact size I need and I can cut from the nest print out. I do the same thing for laminate and particle board for tops. For laminate I added a sheet stock of 60 x 144 and 48 x 96. I just type in the sizes I need and it lays it out for me. Particle board is no different. I entered a sheet stock of 49 x 97 and do the same thing. Works great.
John Desmond
John Desmond
