Cathedral Doors
Donald L Estes
Company Name: Estes Constr + Woodwrkg
Cathedral Doors
Postby Donald L Estes » Wed, Jan 09 2013, 3:54PM
In Door/ Drawer Editor there are a couple doors with Cathedral raised panels, is it possible to make door with top of top rail in a cathedral shape to follow Cathedral Shape of Raised Panel ?
How to do this ?
Scott G Vaal
Re: Cathedral Doors
Postby Scott G Vaal » Mon, Jan 14 2013, 8:58AM
Donald,
Not sure we understand what you are wanting to do here. If you can, please give a little more info/details about what you are wanting.
Donald L Estes
Re: Cathedral Doors
Postby Donald L Estes » Mon, Jan 14 2013, 10:05AM
All doors in Door/ Drawer Editor are square top doors, there one in the Conestoga catalog, and one in the Thermwood catalog, that has a cathedral shaped raised panel and the bottom of the top rail is in a cathedral shape that follows shape of raised panel, I want the top rail to be substanially wider and the top of the top rail in the same cathedral shape as the bottom of the top rail, for instance, stiles 2.5" wide, bottom rail 2.5" wide, top rail 8.5" wide, with catedral shape at top of door.
Also on another problem, also in Door/Drawer Editor the button that says "CREATE MATCHING DRAWER" I often get respose that matching drawer is "NOT AVAILABLE" .The button says "CREATE" not pick
from available drawers, we should be able to create a matching drawer front. Thanks for Help
Scott G Vaal
Re: Cathedral Doors
Postby Scott G Vaal » Tue, Jan 15 2013, 11:15AM
Donald,
We currently do not have any stock doors in the software that have an arch or cathedral shape on the exterior of the door. You would have to use the part editor to get something to look like what you are wanting.
Neville Bastian
Re: Cathedral Doors
Postby Neville Bastian » Tue, Jan 15 2013, 9:48PM
Donald, Even if Scott did give you a cathedral door it would be single pass. The door designs are so limited they reallly can't be used. There is no flexabilty with edge treatment or how the pattern works with a bank of drawers or pantry full height door with mid rail for example.
The main reason could be is the panelmatrix program they sell that has been written by the Canadians. This has many door designs including the one you ask about. Maybe Scott can send you a link if you want to know more.
Regards
Neville
Neville Australia
Users browsing this forum: No registered users and 14 guests
