how to dado all the primeter edges of a board
I have attached 3D model how I want the board to be machined. I am a new user of e-cabinet, please explain in very detailed instruction. Many thanks!
May
May
- dado primeter edges.png (9.26 KiB) Viewed 15512 times
Re: how to dado all the primeter edges of a board
Create a cabinet with only a back, take that part into the part editor and then use a profile modeling tool to create the rabbet. The machine would have to be set up accordingly.
- Josh Rayburn
Why don't you try and use a cabinet back -
In construction settings, change all the joinery to full dado with 0" fit and depth clearance.
Then adjust the back flush / side flush settings etc. until the back has the rabbets in it the way you have shown.
Hope this helps,
Hope this helps,
Hi Josh, that is a great help. I got it. I can sleep well now. May
I get your idea. will try tomorrow. Thanks!
Hi Josh, I followed your instruction, and did it. Now, I want to make it a frame with constraint. First, after I extrude cut the rectangular out, I saw the picture like I attached. But, after I add constraint on the the frame width 2.75", the dado around the perimeter is gone. Why? I cannot figure it out.
May
- dado primeter edges frame.png (11.67 KiB) Viewed 15431 times
- Josh Rayburn
Hi Josh,
That is so cool!
Many thanks!
May
That is so cool!
Many thanks!
May
how to adjust the length of a blind dado
Hi Josh,
I found the blind dado is way too long than the tenon, I understand it has to be longer because of the radius of the tool. I attached the pictures to show how much longer they are. How to shorten the length of the blind dado?
May
May
- Josh Rayburn
May,
You will not be able to shorten the dado operation. We have no control over this.
Sorry I'm sure that's not too helpful -
Thank you Josh, you save me a lot of time to trouble with the length.Josh Rayburn wrote:May,
have a wonderful day!
May
