how to dado all the primeter edges of a board
May Cui
Company Name: misani
Postby May Cui » Thu, Oct 10 2013, 3:16PM
I have attached 3D model how I want the board to be machined. I am a new user of e-cabinet, please explain in very detailed instruction. Many thanks!
May
dado primeter edges.png (9.26 KiB) Viewed 7552 times
Daniel Odom
Re: how to dado all the primeter edges of a board
Postby Daniel Odom » Fri, Oct 11 2013, 11:01AM
Create a cabinet with only a back, take that part into the part editor and then use a profile modeling tool to create the rabbet. The machine would have to be set up accordingly.
Company Name: Halls Edge Inc
Postby Josh Rayburn » Mon, Oct 14 2013, 7:43AM
Why don't you try and use a cabinet back -
In construction settings, change all the joinery to full dado with 0" fit and depth clearance.
Then adjust the back flush / side flush settings etc. until the back has the rabbets in it the way you have shown.
Hope this helps,
May Cui
Postby May Cui » Mon, Oct 14 2013, 10:08PM
Hi Josh, that is a great help. I got it. I can sleep well now. May
May Cui
Postby May Cui » Mon, Oct 14 2013, 10:11PM
I get your idea. will try tomorrow. Thanks!
May Cui
Postby May Cui » Tue, Oct 15 2013, 3:50PM
Hi Josh, I followed your instruction, and did it. Now, I want to make it a frame with constraint. First, after I extrude cut the rectangular out, I saw the picture like I attached. But, after I add constraint on the the frame width 2.75", the dado around the perimeter is gone. Why? I cannot figure it out. :wall: May
dado primeter edges frame.png (11.67 KiB) Viewed 7471 times
Postby Josh Rayburn » Wed, Oct 16 2013, 7:40AM
Maybe this will help -
http://screencast.com/t/nppSAwrQP
May Cui
Postby May Cui » Wed, Oct 16 2013, 9:12AM
Hi Josh,
That is so cool!
Many thanks!
May
May Cui
how to adjust the length of a blind dado
Postby May Cui » Tue, Oct 29 2013, 1:31PM
Hi Josh,
I found the blind dado is way too long than the tenon, I understand it has to be longer because of the radius of the tool. I attached the pictures to show how much longer they are. How to shorten the length of the blind dado?
May
blind dado 5mm too long2
blind dado 5mm too long1
Postby Josh Rayburn » Wed, Oct 30 2013, 6:52AM
May,
You will not be able to shorten the dado operation. We have no control over this.
Sorry I'm sure that's not too helpful -
May Cui
Postby May Cui » Wed, Oct 30 2013, 7:13AM
Josh Rayburn wrote:May,
Thank you Josh, you save me a lot of time to trouble with the length. :D
have a wonderful day!
May
Users browsing this forum: No registered users and 37 guests
