Changing door / drawer front textures.
Rick Nagy
Company Name: Ricks Cabinet Shop
Postby Rick Nagy » Thu, Oct 17 2013, 8:34AM
Hi,
I want to add a black oak texture to my doors / drawer fronts. I copied the image from the library to users/conestoga/finishes/red oak. It comes up as a texture/finish option when I go to edit the door. I'll select it, change the doors, then when it is rendered, it is not changed. Thoughts?
Greg Nagy
Company Name: Barracuda Kitchens
Country: AUSTRALIA
Re: Changing door / drawer front textures.
Postby Greg Nagy » Sat, Oct 19 2013, 2:48AM
Try to create a material with this texture, then in the cabinet editor make anything using this material. Then click on this part, then click Match Texture from the right click menu, then click on your drawer fronts. Finally you can delete the temporary part what you don't need. It should work I think.
PS: are you Hungarian?
Scott Marshburn
Postby Scott Marshburn » Sat, Oct 19 2013, 6:11AM
In Cabinet Assembly Editor
1) In settings and Preferences create the materials with the texture that you want.
2) In construction settings assign this material to the parts that you would like to be made from this material
3) Add the doors and drawer fronts and return to main
4)Click one part with the texture that you would like your doors and drawer fronts to be then click on the doors and drawer fronts
5)Right click and select match Texture.
6]Click on the highlighted part with the texture that you want the doors and drawer fronts to be
In Custom Layout
1)Right click and select edit options. From the drop down window select modify textures
2)Find Conestoga Door/Drawer and click on the Column that says Not Set
3)Find the material texture that you would like the doors and drawer fronts to be and select it and click ok
4)Click Apply in the modify textures window. The click OK.
Note: This method will change all Conestoga doors and drawer fronts in custom layout. And will only show the texture when rendered.
Rick Nagy
Postby Rick Nagy » Sat, Oct 19 2013, 11:37AM
Thanks for the info, I'll give that a try. Yes, I am Polish Hungarian..
