Hardware database update failed
Brent Pister
Company Name: Brelin Quality Builders
Postby Brent Pister » Thu, Mar 13 2014, 8:55AM
Downloaded ecabs to new computer. When I try to run system, the message "hardware database update failed" pops up. Tried to reload program but get the same message.
What would be the fix.
Brent
Scott G Vaal
Re: Hardware database update failed
Postby Scott G Vaal » Thu, Mar 13 2014, 10:12AM
I will assume that the new PC has Windows 8 or 8.1. If so, try doing the following:
> Go to Control Panel, Programs and Features, then select Turn Windows features on or off.
> Now, in the Windows Features dialog, Check on the .NET Framework 3.5 (includes .NET 2.0 and 3.0) option (see attached picture), then select OK. Download the required files and let it install.
> Re-run the eCabinet Systems install and choose the Repair option.
> Launch eCabinet Systems and see if the issue is resolved.
Windows Features1.jpg (42.35 KiB) Viewed 1316 times
Brent Pister
Postby Brent Pister » Thu, Mar 13 2014, 12:54PM
Thanks for the fast response, Scott. That worked perfectly
Brent
Scott G Vaal
Postby Scott G Vaal » Thu, Mar 13 2014, 3:55PM
Brent,
Glad it got you going. Thank you for the feedback.
Users browsing this forum: No registered users and 8 guests
