Crashing on Render with Pulls
TonyGiunta
Company Name: ToSa Design
Postby TonyGiunta » Tue, Mar 25 2014, 9:40AM
Have the latest v13. While in Custom Layout and go to render the project, it immediately crashes. If I hide the pulls it doesn't crash. Any suggestions on cause and fix appreciated. Thanks.
Scott G Vaal
Re: Crashing on Render with Pulls
Postby Scott G Vaal » Tue, Mar 25 2014, 10:36AM
Tony,
We have discovered an issue with the Pull Detail option in the presentation view causing a crash situation if it is not set to max. Please do the following and it should take care of your situation. Go to the Render View area, then select the Presentation Settings button on the left. Set the Pull Detail slider all the way to the Max position, then select OK. Now, perform the presentation view and it should work for you. This will be resolved in the next build.
TonyGiunta
Postby TonyGiunta » Tue, Mar 25 2014, 11:03AM
Scott,
Thanks that did it.
Tony
Al dedenus
Country: NEW ZEALAND
Postby Al dedenus » Wed, Mar 26 2014, 12:50AM
Yup, had the same problem and it worked for me too :D
