Group Parts - Drawers - Assembly
Stephane Kovari
Company Name: Aspec
Postby Stephane Kovari » Tue, Mar 25 2014, 2:02PM
I've been trying to group a line of Drawer fronts across 3 cabinet,s approx. 30'' wide 6'' high with the grain going the length of all three cabinets.
When I add the drawers into the cabinet it always sais the width is 30'' and the height is 6'' even when I rotate the grain, and because it thinks it is 30'' wide, it doesn't nest my drawer fronts into my material at the CNC?!?
Does anyone know of a solution or why it does this??
Stéphane
Scott G Vaal
Re: Group Parts - Drawers - Assembly
Postby Scott G Vaal » Tue, Mar 25 2014, 2:19PM
Stephane,
Please post your assembly and I will try to figure it out for you.
Stephane Kovari
Company Name: Aspec
Postby Stephane Kovari » Wed, Mar 26 2014, 6:24AM
Here are two assemblies that we tried. One works since the Grains is in-line with the heigth and width.
E03-E04.esa
(2.16 MiB) Downloaded 80 times
C01-C02.esa
(1.98 MiB) Downloaded 86 times
Scott G Vaal
Postby Scott G Vaal » Wed, Mar 26 2014, 8:47AM
Stephane,
All seems to work here for me. I believe your issue is that you do not have the newest Control Nesting installed at your machine. Version 5.78 of CN is required to do assembly grouped parts (older versions do not know how to handle this new feature). Please verify this and let me know. One other item that I noticed was that I believe you may have your width and length swapped for your material named (MDF dos Blanc .625 4x8 bottom). This will probably give you an out of bounds message if you tried to run that sheet at the machine. Hope this helps.
Stephane Kovari
Company Name: Aspec
Postby Stephane Kovari » Thu, Mar 27 2014, 9:14AM
The control Nesting is V5.78 but it seems to believe that the drawers are 14'' wide and 6'' high (in a way is true) but the drawer front with grain is 14'' long and 6'' wide and this causes en error in nesting at the CNC...
Scott G Vaal
Postby Scott G Vaal » Thu, Mar 27 2014, 9:36AM
Stephane,
Please send me an export from Control Nesting at the machine. To do an Export: load the .twd that causes the issue into Control Nesting, then select File -> Export, then send me the .cab file it created. (send it to cabinets@thermwood.com Attn: Scott V in the subject line)
Scott G Vaal
Postby Scott G Vaal » Thu, Apr 03 2014, 10:19AM
Stephane,
Thanks for getting me the export file. It helped me isolate the problem. It is a bug with assembly grouping that ONLY happens when multiple grain matched assemblies exist in a single Batch Job. We will have this resolved in the next eCabSys build, but for now, you can get them to nest/cut just fine by placing them into a Custom Layout (a room) instead and then creating the CNC. Or you could also put each assembly into a separate batch job and then load them together at the machine (Control Nesting) and they will nest fine as well.
Stephane Kovari
Company Name: Aspec
Postby Stephane Kovari » Wed, Apr 09 2014, 7:04AM
The new Update has resolved this problem!! Thank You!!!
All thats missing for us now is an option for shelf holes in the back and to be able to split backs without using stretchers :)
Again Thanks!
