Batch 'View'
Nat Wheatley
Batch 'View'
Postby Nat Wheatley » Tue, May 13 2014, 12:13PM
When I'm in the batch area, entering cabinets, I click on the 'view' tab, and select 'collapsed'. The thumbnails collapse as they should. When I go from there to the cabinet editor, then back to batch, the list has gone back to thumbnails.
Is there a way to make the view selection stick?
Nat Wheatley
Re: Batch 'View'
Postby Nat Wheatley » Fri, May 16 2014, 4:36AM
Anyone?
Scott G Vaal
Re: Batch 'View'
Postby Scott G Vaal » Fri, May 16 2014, 8:39AM
Nat,
There seems to be some kind of conflict happening between areas that is reverting this setting back. I will add it to the list to be looked at. For now, if you change it to collapsed (or whatever you are wanting at the time) and then shut down eCabinet Systems and restart, it will hold on to the choice you made between areas.
Nat Wheatley
Re: Batch 'View'
Postby Nat Wheatley » Fri, May 16 2014, 11:16AM
Thanks Scott.
Users browsing this forum: No registered users and 36 guests
