Part Editor_Circle Mode_PROBLEM!
Vince Lisanti
Postby Vince Lisanti » Wed, Jun 11 2014, 8:45AM
For whatever reason the part editor is not working for me this morning. This is not specific to any one cabinet. Does not work even when using standard cabinets.
I am trying to create a set of holes on the left end of a case. The side that faces out not the interior. I select the part, go into part editor, click back view, click the circle tool, place the hole geometry. When I go to click on the hole geometry so I can use the "Cut/Pocket Using Geometric Shapes" it will not highlight the geometry. Nothing happens.
I am not in closed contour just the main area of the part editor. This is only with the circle tool not the rectangle tool. The rectangle tool works fine.
I really need to get this issue resolved.
Dell Precision M6500
Intel(R) Core(TM) i7 CPU Q 740 @ 1.73GHz (8 CPUs), ~1.7GHz 4.00 GB RAM
NVIDIA Quadro FX 2800M
Windows 7 Professional 64-bit
Vince Lisanti
Re: Part Editor_Circle Mode_PROBLEM!
Postby Vince Lisanti » Wed, Jun 11 2014, 9:00AM
I figured it out. Somehow the snap setting was set to 0 and that is why I could no select circles
Users browsing this forum: No registered users and 12 guests
