For whatever reason the part editor is not working for me this morning. This is not specific to any one cabinet. Does not work even when using standard cabinets.
I am trying to create a set of holes on the left end of a case. The side that faces out not the interior. I select the part, go into part editor, click back view, click the circle tool, place the hole geometry. When I go to click on the hole geometry so I can use the "Cut/Pocket Using Geometric Shapes" it will not highlight the geometry. Nothing happens.
I am not in closed contour just the main area of the part editor. This is only with the circle tool not the rectangle tool. The rectangle tool works fine.
I really need to get this issue resolved.
Part Editor_Circle Mode_PROBLEM!
Dell Precision M4800
32 GB RAM
NVIDIA Quadro K 2100M
32 GB RAM
Re: Part Editor_Circle Mode_PROBLEM!
I figured it out. Somehow the snap setting was set to 0 and that is why I could no select circles
32 GB RAM
32 GB RAM
